Jack Stand Locations, please help
Searched but came up empty. Want to jack all 4 wheels to paint calipers. Pics of jack stand locations would be great!
Thanks
on the length of the frame there are "slos" that are about 1/8 recessed up. right past the side skirt. That is a good place for it. There are 2 right behind the front tires and 2 infront of the rear.
it is right behind the front tire and straight down from side mirror.
it is like ----^---- a little cut off. thats where i put my jack.
rear too.
if you want to jack up your rear you can use the guard plate that is in the middle of the rear sway bar. and then place your jacks in the -----^------ grooves of the frame.
I jacked up all four with ease, albeit with an unlevel driveway, and painted the calipers. Piece of cake. Thanks for the input.
