ITR rims fit MP3 ?
turboboy
Hi guys,
Just wondering if anyone on the board knows if the ITR rims fit on our MP3 ? I could get a set of gunmetal ITR rims for cheap and I'm planning to use them for autocross. The bolt pattern for our car is
5 X 114 right ? And what's the offset ? Thanks for all the help !
If you use the search function, all of the info is available. BUT, since you are new, this is your gimme.
They are 5x114.3 (or 5x4.5) and the offset from the factory is 55, but I have heard you can do a 42 safely. Don't quote me on that though. Make sure that if you do get rims, they have a proper centering ring. Very important.
Good luck, welcome to the board, and try the search function. Almost everything about stock info has been covered.
MP3 and P5 5 X 114.3
ITR is 5 X 114
dunno if they will fit as it might be mm or cm or inches... who knows.... not me though...
Jc
They are the same bolt pattern, 5x114.3 (no such thing as a 5x114 as far as I know) But the offset is different, Honda's use a much lower offset than what we need in our cars, ITR wheels will rub.
Shawn
they will probably rub. i have kosei rt penta wheels in a 47 offset and they are very close to rubbing(car is lowered with H&R springs). i would not go much lower in the offset than that.
