is there a waterspray kit ?
just by a snow performance methonol kit for a mustang a use it on your MS3, it doesn't plug into your stock ECU that what i am going to do, or make a spray bar for nitrous cool the IC charge
Refonbass said:
I think two different things are being referred to here... ?
Ya I believe the original question was for the IC water spray (albeit Im not sure how it would work given the hood design)
You could get something like this:
http://www.speedmethodperformance.com/products/1207smartsprayintercoolerspraycontroller.htm
Or you might get some brass plumbing bits from your local hardware store and move your rear washer hose so when you hit the rear washer switch it gives your intercooler a good cool-down. You probably want to switch to deionized water in the washer bottle though unless you want a real mess under your hood.
(Note: I stole this picture from a mini forum - I hope no one notices...)
ptperformance said:
Yes there is. Give me a week or two and I should have a kit up and running with either direct port or single port injection.
Any news yet?
benzo said:
Any news yet?
No sorry we had some PC issues and working from the laptop as well as a recall on turbos for the srt4 has taken all my time. I have the intake off and I will be getting the injection started very soon. In order to really see the gains I will need to up the boost and monitor engine knock so getting more boost is kind of prioirty first. To many things started and now I just need to pick one and go with it. Ported intake might be the first thing installed after the track day I will have the fittings on there I will just have to get the WI started for it.
