I'm guessing no-one read my link? Fine then, I'll just post what it said.
From C&D:
Your Car is a Temple, so Put in the Good Stuff. - Column
BY LARRY WEBSTER
August 2005
At a local Mobil station, a gallon of unleaded regular gas goes for $2.15. Drive a mile down to the nearby superstore that sells everything from apples to swimming pools, and it's $2.10 a gallon.
Supposedly, the superstore buys gas in such large quantities that it gets a volume discount for what is essentially the same product as the name-brand stuff. The Mobils and Chevrons of the world say they include costly additives and detergents that keep your engine free of deposits and make your car perform better. So what's the truth?
To find out, I paid a visit to Andrew Buczynsky, GM's fuel guru. He says that with gas, like almost everything else, you do get what you pay for. Buy cheap fuel, and you risk coating parts of your engine with thick deposits that can dramatically affect your car's performance. There are a number of possible conditions including sticky intake valves and clogged fuel injectors.
Choked injectors distribute fuel unevenly, so instead of having a well-mixed brew of gasoline and air entering the combustion chamber, you get an intake charge with pockets of too much fuel and alternatively lean portions. If there's not enough fuel around the spark plug when it sparks, then you don't get the usual combustion that drives the piston downward. In technical terms it's known as a misfire.
Every engine misfires now and then, but misfires usually occur so infrequently that the driver never notices. The car's engine computer knows what's up, though. When the frequency of misfires reaches a certain point, the computer raises a red flag and turns on the "service engine soon" light on the dash. Uh-oh, we know what that means—a dreaded trip to the dealer. Ignore the light, and the misfires may get frequent enough that the car feels sluggish.
The repair for this type of problem depends on the severity of the deposits. In mild cases, the technician may be able to simply scrape clean the fuel injectors or sometimes a bottle of fuel-injector cleaner will do the trick. In some cases, though, the fuel injectors will have to be replaced. If the deposits have formed on the intake valves, then you're looking at a cylinder-head rebuild. The cost of the repair will depend on the severity of the problem and whether your car has a warranty in effect. The worst case, however, could mean a bill of more than $1000.
Buczynsky says the exact cause of engine deposits is not known. Gasoline contains over 200 different molecules, and so far, no one has isolated a particular brew that is more likely to cause engine deposits. GM and other manufacturers, however, noticed there were regional concentrations of fuel-system warranty claims and traced the problem to the fuel.
Gasoline is gasoline whether you're in Florida or California, right? Wrong. There are different concentrations of elements like sulfur, for example, that change the chemical composition of a batch of gasoline.
Since it's not known what causes these deposits, gasoline retailers can't be penalized for selling defective fuel. So to keep the deposits from forming in the engines, you need detergents added to the fuel.
But how do you know which brands have the right kinds of detergents and additives to keep your injectors clean? Until recently, that was a tough question to answer, but in 2004, representatives from BMW, General Motors, Honda, and Toyota got together to specify what makes a good fuel.
They called their agreed-on standard "Top Tier" and published it for the various gasoline retailers to voluntarily meet. So far, eight companies currently sell gas that meets the Top Tier standard. You can read about them at
www.toptiergas.com. At some point there will also be a Top Tier logo on the pumps like the one pictured here. For a company to receive the Top Tier seal, it has to certify every grade of fuel, not just the high-octane stuff.
Now, if a certain brand of gas doesn't meet the standard, it doesn't necessarily mean that one tankful will harm your engine. And Buczynsky was quick to point out that using non-Top Tier gas won't void your warranty. But, he says, using Top Tier fuel will keep your engine cleaner. That will not only lower the chance of the "service engine soon" light coming on but will also improve your fuel economy and reduce emissions.
As for the various engine-cleaning additives available at auto-parts stores, Buczynsky says they should be used with caution. He said some work but most don't and declined to identify the ones that do. You also have to be careful when using these additives because some may contaminate the catalytic converter. Also, if you use too much, the additive may cling to valve stems and cause them to hang open.
The message was pretty clear: Stick to Top Tier fuel. It's the only way to know you're getting the right amount and type of detergents to keep your engine clean.
I didn't forget to ask the question we all want answered: Is there a brand or type of fuel that produces more horsepower than the rest? The short answer: no. That's not news because in November 2001 (Tech Stuff: "Regular or Premium?") we tested a fleet of cars on regular and premium fuels and the results are worth repeating. If your car specifies premium 91-octane fuel and you run regular, then the engine computer automatically detunes it to avoid the detonation that low-octane fuel can produce. (Detonation, you'll remember, is erratic, uncontrolled combustion that can seriously damage your engine.) In most cases, we're talking about very small horsepower losses, but if you want your car to produce all its beans, put in the recommended octane.
For horsepower freaks who've cranked up the boost in their turbocharged cars or modified their engines and need higher-octane fuel, VP Racing Fuels recently introduced 100-octane unleaded, called StreetBlaze 100, that's street legal in every state. You can find retail locations at
www.vpracingfuels.com.
One of the many things Buczynsky said made particular sense: "If you have a highly sophisticated car like the type we have today, the fuel has to keep up."
