AutoEuphoria
- '08 CPW Mazdaspeed 3
I've been having some issues lately with my car...I've posted in other sections, but I'd like to post this log here to help ask a related question:
Notice the fuel pressure is ridiculously low. I have been babying the car since that datalog waiting for the big monthly bills to get out of the way so I can order another set of fuel pump internals. However, I am just curious if anything else would cause low fuel pressure other than a failing fuel pump? I noticed today that when I got in my car at lunch (cold engine) I saw fuel pressure of <100psi at one point just accelerating lightly up to the speed limit. However, later (after engine was warm) I was seeing fuel pressures of 1600+psi. So, I'm just confused.
My main question, I suppose, is if the MAP sensor or Boost control solenoid would cause low fuel pressure if either were acting up? I didn't notice this kind of low fuel pressure until after I removed the MAP clamp (which tapped into the MAP sensor wire) and manual boost controller (which bypassed the BCS).
Thank you for any help/input/suggestions/etc. (drinks)
