iPhone mount?
2016 cx9
Hi all - anyone using an iPhone mount in their '16 CX-9?
I'm looking for something that looks good and works well but not finding much out there.
What are you guys using? Thanks!
The magnet mounts are the best thing since sliced bread. Just put the slim metal sticker inside the case (use a dual layer case and stick the metal to the inside of the outer shell so you don't see it). Mount the magnet anywhere (I use the vent mount but they sell other kinds). No more fumbling with the spring loaded holder. Just stick your phone on the magnet, and pull it off when you leave the car.
And its cheap!
Check out ProClip.
They have a mount that secures to the side of the center console.
That gets paired with a phone-specific holder.
On the iPad or I'd post a pic of mine ... love it!
I've been using this for my iPhone 6s. It clips to the vent. I only had to adjust it once and all I do now is slide it on the lowest rung of the vent fin. I adjusted it so that it's snug enough that it stays put but can still be pulled out when not in use. It has rubber pads on the clips so it can grip but not scratch the vent fins.
Aikema PH05 Air Vent Car Mount Holder with 360 Rotate for Smartphones - Single https://www.amazon.com (commissions earned)
