rear mount install tips(long)
I have both mounts in my 2001 LX ,As people have said the front is easy . The rear however is a pain to change with the engine in ,good news it can be done ,I did it .
You will need to a few people to help . First jack the car up as high as you can support with jack stands . For tools you will need a 17mm inpact universal socket and varios extensions .
Step 1 .remove the intake hose from the TB to the MAS ,this allows access to the main wire harness,there you will find a plastic bracket that is held on with 10mm nuts ,remove these . Then pull the wire harness out of the way .
Step2 using the 17mm universal socket and the extensions losen the 17mm nuts .
Step 3 From under the car there are 3 bolts in the trans that must removed ,used your 17mm socket and an air gun ( theses suckers are tight )to losen the bolts . remove the bolts .
step4 Back up top remove the 3 17mm nuts
Step5 go back underneath the car ,there is a 10mm bolt that must be removed from the lower bracket then you can remove the assembly with some twisting and swearing the mount and bracket will come out . Put on the new mount . And reverse what you did. This is were the extra people come in you need 4 hand to put it back together.
