Inner Tie Rod Installation Questions
smetzger
03 P5, 09 Miata, 13 Fit, 09 Ody, 99 Civic
Inner tie rod has is a tabbed lock ring. The tabs are bent towards the outside of the car.
1) Is this lock ring really necessary?
2) For removal I banged the tabs out with a screwdriver. How to I install the new one, since I would be bending them towards me?
I got it on...Was only able to bend one of the four sides of the lock ring...
Follow up weirdness....
  • Before new inner and outer tie rods...
  • Left side, I could shake the wheel side to side and top to bottom. I did not get any grinding sound when rotating the tire
  • Right side, I could only shake the wheel side to side. Top to bottom was solid. I did not get any grinding sound when rotating the tire
After installation, symptoms on right and left side switched...
  • Left side - can only shake side to side
  • right side - can shake side to side and top to bottom
What the heck is going on here?
Do I have bad bearings? As far as I can tell the control arms are good
