Injen Cold Air Intake - Turkey
eniN6
i currently purchased a injen cia and a greddy type rs bov, however i was unaware that i would need hardpipes for the bov, is there any way to eliminate the turkey sound from the cia?
unless theres a way to install the BOV without hardpipes? this turkey noise is getting annoying already.
I found that out the hard way. Running Injen CIA with a turbosmart dual port bov and hard pipe kit and using the factory valve too. When I wasn't running the stock bypass vavle, it ran a little iffy. I put it back on and now it's pretty smooth.
you will have to get hard pipes, the turkey should go away once you install the bov. mine is gone and im running the hks ssqv bov
