Infotainment Question - display ALWAYS displays the next road ??
DBLXX
Is there a way to stop the display from displaying the next road while you are NOT using the GPS?
When I have the radio on...it displays on top.
When I have the fuel economy display on it displays on top.
I could/would understand if I were actually navigating to somewhere....but it does it all the time.
Thanks
Would also like to know. I haven't found anything in the settings that can change it to display e.g. the current radio station or music track that's playing.
Same here. I also would like to know how Radio favorites could just display the favorites for the source I'm listening to. For example, if I'm listening to XM radio I couldn't care less what my FM or AM favorites are and would like to just browse through my favorites XM channels.
I only listen to SiriusXM so I only program in SiriusXM channels thus always get them when I hit the STAR button.
But I see where your frustration is.
I have noticed that using the steering wheel mounted controls to change stations will only cycle through the favorites of the source currently being listened to (e.g. only the XM favorites).
+1
Thanks a lot. I'll use the steering controls then.
Edit: better than nothing BUT it's not completely satisfactory. Using the steering wheel commands cycles from one XM channel to the next in the list. I was looking for a way to scroll down the list and directly select the XM channel I want to listen to.
Agreed, it's better than nothing.
It's too bad some vehicle manufacturers have moved almost completely away from buttons/knobs and towards touchscreens. Being able to feel buttons (e.g. radio station presets) while driving can be faster and safer. I'm glad Mazda has included a Commander Switch/Knob in its latest vehicles to complement the touchscreen. With this and the steering wheel mounted controls, I don't really find myself having to use the touchscreen much.
I found the solution! In XM source (not in FM and AM) there's a Channels List option at the bottom of the screen (2nd from the left). Selecting it with the Commander knob shows the list of my favorite XM channels. I can scroll and select whatever XM channel I want.
Problem solved.
Problem solved.
Good find, thanks!
I found that has changed with the new firmware up date (55). It used to only do AM/FM or XM. Now it scrolls all the way through your faves.
