If the MSPs can get their ECUs flashed...
Matthew
Contributor
CX9, CX5, i8
why cant we find the file for the dealership to download with the stock mp3 settings? put it on disk and take it to em or something
dealerships around here have it i know, pm cdglowp5, he'll give you all the info.
thanks im gonna see what info i can get...do you know the basics of what he did derrick?
but razor,
you're gonna have to run premium gas like the turbo'd kids... except without the turbo's power. don't do it man!!! 20 cents a gallon, 12 gallons per fill up, $2.40 a tank, ~$10 a month, ~$120 a year. all for very minimal gains.
i see...some are talkin up to ten horses, i wish someone dynoed the difference in a p5 without the turbo so i could see but i couldnt find the result.
The result of the MP3 ECu was less then 3 whp and over a very small band.
You do not have to run premium with the stock MP3 ECU. The car is not going to knock even with 87 octane.
i think he meant less than 3hp at the peak... let me look at the dyno....
yep... 3whp all the way at the 6Krpm mark. i don't think it's worth the extra money on fuel, do you?
Sorry i ment less then 3 whp.
The MP3 form the facotry was rated at the flywheel for 140 hp, 10 more then the P5 which they said was do to the Exhuast (just a muffler) and the ECU. Without the muffler involved as the dyno was done on an MP3, the resuklt was a 3 hp decrees at max whne a P5 ecu was swaped in.
so its less than 3 hp or lose 3? i must be an idiot craig cause it looks like you contradict yourself here. :(
Read again!
On an MP3 if you put in a P5 ecu you will loose about 2.5 whp
In a P5 if you put in an MP3 ECU you will gain (maybe) about 2.5 whp. Its harder to tell here becuase the MP3 that FM had obviouly had the Racing beat muffler on it.
