I have a 2002 Mazda Protege 5.... with some idle issues and loss of power.... I have a new (reman) engine, ran ok for a bit, but still light on power, after about 1500-2000 miles maybe a bit more...the check engine light came on gave some codes lead to random mis-fire, cat issues, and gas (small little piece on back of engine)...
I have put in a new lower Cat, and cut out the front cat (header installed),
Put in new coils, new plugs, two fuel parts, .....all issues fixed except random missfire...P0300
taken to two shops, one shop seems to have narrowed down stating possible timing issue, but that should be under warranty, however I think the shop that did the engine is closed down, phones disconnected...havent had a chance to go by yet...
after the header installed and front cat gone, the light has stayed off, although only driven about 6 miles, but still off...last time it was on within 3....
Any ideas on random mis-fire?
Codes:
P1250 Pressure regulator control solenoid valve malfunction - replaced both the control and the regulator
now the big issue::
P0300 Random/Multiple Cylinder Misfire Detected
this is the one that seems to cause the biggest issue....
Mechanic suggest timing issue, but states that can't be tested with light, has some other machine that measures wave lengths....
He tested compression and stated that was good, but more or less at a loss unless timing sounds like a good chance???
Codes:
now the big issue::
