tweety2300
- 2001 mazda protege mp3
Just got a turbo and having a hard time figuring out what it is, from what I can pull up on google the hot side is a Garrett gt3076 with t2 flange, cold side has no markings and looks eBay.
On the flange it has the numbers 449010-1
On the hot side it has .64 and m3
Center section has no plate but has k2 stamp
Cold side has no markings at all
There is also no plate giving pn or sn.
When I spin it it won't stay spinning which from what I read means its journal bearing, or at least I hope it is cause it has a lot of in/out shaft play and needs rebuilt. But it has water and oil lines which most ball bearings have. I need to figure out what it is so I can have it rebuilt. Never pulled one apart before but I'm guessing I'm going to have to so I can measure everything and see if its ball or journal bearing
