Ideas for hiding sub in trunk
that's a pretty cool install, i'm going to work on somthing similar, except i want to put a ten on each side, and have my amp in the center under a plexi glass false floor
You guys might want to consider earthquakes new line of slim subs to mount in the tire well.
That's a cool install. I would love to do fiberglass eventually one day...but for now, I'm just going to have a plain square box on the right side, and the amps on a board behind the seat...thinking of pivoting the board so it will fold down with the seats...
And the Amp Board will look like this...see attached...(simple for now...)
(bluep5)
i'd suggest drilling some holes in the board near the amp and the fuse holder and run the wires thru it so they arn't visable, it would clean that intall up a ton. looks good otherwise.
Good Point, I will consider re-doing it, I'll probably run it this way for a little while until I cut a different size board.
Thanks for the suggestion!
