20EVOLUTION01
I got My Header! I can't wait to put it on. Still have to weld the EGR Bung and the Second O2 sensor. Can't Wait! Looks beautiful.
(2thumbs)
(2thumbs)
With thickness, you're going to have to go with the closest piping to the desired thickness you want. If it calls for 1.8" Primaries, go with 1.75".iluvmacs said:I've been playing around with the header design program for a while, and have come up with a few trends:
Primary pipe diameter changes by less than .25" thickness, which would seem to make fabrication difficult.
Primary pipe length is around 32". I assume that this is primarily for exhaust pulses, which can be reduced by a factor of 2, 3,4, etc. The difference being how many times the pulse wave travels the length of the pipe.
I just wanted to note that the only header with primary pipes anywhere near that length was the ES equal length (non-shorty), and the ractive 4-1. The AWR looks like it has 8-10 inch primaries, and narrow collectors.
Comments?
I call them Tri-Ys myself, but not everyone knows the reference. They do promote a broad torque range, and can be less peaky than a 4-1. But chances are, a well designed 4-1 can make almost as much low RPM power as a Tri-Y, but peak HP is no comparison. 4-1s make substantially more up top....PR5Matt said:The 4-2-1 is just the 4cyl version of the old Doug Thorley tri-Y v-8 headers. They are supposed to promote a broad torque range.
I agree. You should see my beautiful 1 3/4"-1 7/8" step primary ceramic coated Bassini long tubes for the 'Stang. I can't wait to put 'em in! I just got them 3 weeks ago. Much better than the Mac 1 3/4" headers.Gen1GT said:I call them Tri-Ys myself, but not everyone knows the reference. They do promote a broad torque range, and can be less peaky than a 4-1. But chances are, a well designed 4-1 can make almost as much low RPM power as a Tri-Y, but peak HP is no comparison. 4-1s make substantially more up top....
In short - don't stick to the stock cams. Don't even CONSIDER the JDM cams if you are serious about making all motor power.
