I stumbled upon something!
I do not disagree that Huerta is an excellent fighter. Guida is a crazed animal and I think he had Roger's number that night. Roger caught a lucky break .. they were both gassed and it came down to heart, imo.
Mid-life,
My wrists have evolved into massive pistons which do not tire...I have never been able to see well.
huerta is a badass. every fight he's been in he gives his all and doesn't quit. and this isnt the first fight he's come out in the last round and thrown out everything he had. if u see his others its something he tends to do if it gets that far. but they need to give him some good fights as he still hasnt fought any of the big names, guida is just a stepping stone they throw at all the potential guys that are doing well.
keep in mind i have not done this yet or even looked at the internals of the coils, but just out of curiosity, is there an issue with keeping these springs consistent once stretched? do you have to make sure that they are the exact same length for all 4? it almost seems reckless to just go in there and start pulling springs. especially considering the turn ratio that is in the specs? if you stretch it doesn't that change that turn ratio?
Can someone answer GoFast's post? I was wondering the same thing. Are these springs just for putting pressure on contacts in the rubber tube or are they part of the high-voltage circuitry (i.e. an Inductor)?
I'm wondering if smearing some conductive grease on the spark plugs and the springs would accomplish the same thing as the coil stretch or maybe even improve it. If it's a connection issue that should help.
Originally Posted by Speedy3
Since all of you pro tuners seem to be spending all your time on this thread, could one of you respond to the last few posts on:
http://www.mazdas247.com/forum/showt...3694249&page=5
Thanks!
.... Imo the increase boost is causing the spark blowout(as we all know) by pulling on the springs you are only just helping the spring promote stronger conectivity, as long as you pull just enough for all 4 its helping with the blow out/shutter....
If i didnt understand your question sorry!
