They have MP3's in El Salvador? Nice!!
The rear sway on the MP3 is the same as the MSP one, so that should make it a little easier to find.
Hi the rear sway bar can be MSPs too. please let me know,
to buy it
Thanks
Whats the size for the mp3 on the rear sway bar endlinks ? theres about 9 different kinds when i attempted to order from napa
Depends. Are you lowered any? What struts do you have? I've never measured, but I would think the stock mp3 links would be a tad longer since it was slighty lowered from factory compared to other proteges. I would just do a custom set or buy AWR ones and call it a day
The MP3 and MSP endlinks are longer than regular Protege ones though. It was done to keep the swaybar parallel to the ground and prevent it from flipping and facing the other way.
If my memory serves me right, they're around 7" in length..
7.5"
And yes they are longer, but it's counter-intuitive. If you are lowered past stock ride height, you need shorter endlinks to keep the bar parallel and achieve the best pre-load on the bar.
I used to think so as well but if you think about it, lowering the ride height doesn't drop the strut any lower, it drops the components which are resting on the springs. Which is the entire vehicle including the rear crossmember and swaybar. So by lowering the ride height, you actually increase the distance between the strut tab and the swaybar because the swaybar is now lower than it once was, and therefore you need a longer endlinks as opposed to shorter ones.
