clos561 said:i cant find the transmission fluid stik so i can check the fluid lvls.....i know where the oil one is where else are all the fluids where i can check
k thx alot man....my first stickshift car......iill give it a try todaybombermanx said:There's no stick for Manual tranny. you gotta check it at the "fill" plug on the tranny (which means going under the car). the fluid level is good if the level is at the same level as the "fill" hole when it just starts to overflow.
