How to - the BIG3. (caraudio)
Demi
Well Ive mentioned this in a few posts and gotten some questions about it so i though i would toss it up here since i did it this weekend.
The the purpose is to augment the existing electrical system with larger gauge wires, for better continuity between chassis and ground, engine and chassis, and alternator and the positive battery terminal. Look at it like this, if you are running 4 gauge wire to your amp from your battery, how much good is it doing if the alternator wire is 4 gauge or less? Its got to run the power for the whole car and now your amp on top of that through that wire. Like a straw feeding into a garden hose. Same thing goes for your grounds. There is no need to remove and replace the wires that are there already, just add to.
Anyway here ya go. I used 0 gauge, which is likely overkill for most of you, but use the biggest wire you can afford, and dont cheap out, all wire is not created equal. Go with good brands for your wire, also it never hurts to solder you terminals to the wire poking through. This will protect against oxidation increasing the resistance in your wires over time. I didnt do it yet as my iron took a crap on me.
Anywho...
First I got rid of the stock negative terminal. This is optional of course, I just had these stinger upgrades laying around.
Next i removed the bolt from my new grounding spot and exposed the metal with some sand paper. I did the same for both sides of the washer and the bottom of the bolt head.
This is the new ground installed and the new battery terminal. I need some splices for the positive because the wire is too short with the yellow top. You can choose any chassis location you want, but this was easy and the shorter the distance to the battery the better.
Here is where wired block to chassis. Im certain there are better places, but the metal bracket seemed large enough to support the wire size and it hooks right up the the block.
Here is where I ran it off the alternator to the positive side of the battery. I will be throwing some F4 tape around where it gets near the heatshield to protect against chaffing.
Here is the battery all hooked up. The red wire is running to the amp, and there is some much extra because i havent installed my fuse yet. for the love of god install a fuse. Install the fuse (fuses fi you plan to install one on the alternator wire as well) as close to the positive terminal as you can.
Thats it, I noticed it helped right away. The dome lights would dim with the stock speakers cranked, and the dimming is just a little worse with 1000w sub pumping in the back. For people running half or so power than that, this may very well be all you need. I will need an alternator upgrade :(. When i get my meter Ill post some before and after ohm checks.
Oh and credit where credit is due. Here is the link to the thread about it for those that want more info.
Official CarAudio.com Big 3 Thread - Car Audio Forum - CarAudio.com
Good cheat sheet on gauges and watts.
Recommended Power and Ground Cable Sizes
Hope this helps!
a better alternator would definitly be the way to go. not sure what the stock one can handle as is, but anytime ppl add more and more electrical components, they are asking for electrical trouble
btw...with that guage of wire it could almost double as extra chassis support :b
Just out of curiosity Demi... I was checking the voltages on my battery and when my car is cranked i came out with about 13.6-13.8. I thought it was supposted to be 14.4? I checked it when the car was off and the battery was running at 11.95 or so.
Any idea if this is normal or is it my car? RPM changes didnt effect the alternator voltage (which is something I already figured, just tested it out of curosity).
Well there are a lot of things that can affect it, but thats about right. You can lose volts over wire/component resistance, humidity, temps, and your meter can read a little off if it hasnt been zeroed properly. If you were running in the 12 volt range with the car running I would investigate. Also what will change with RMPs is the available amperage. This is a hard thing to measure as amps are pulled so there has to be a demand for it. Your voltage should not change with higher rpms because you voltage regulator is doing its job.
well i was reading 12v when the car was off. that makes sense, I was reading 13.6ish when the car was on. thats about .8 volts low. I think I may check into it a little more.
First place i would look is put your meter right to the alt and see what your getting there. If its higher than what youre getting at the battery then the big3 will clear it up.
90 amp Alternator
Just for those interested in FUSING between the alternator and the battery on this upgrade (which I highly recommend), the alternator is rated at 90amps.
Also, Does anyone know the link of where it shows how to get to or take out the alternator? I know I wont have to remove it but...I need to know how to attach a 1/0 wire to it. Thanks tippythehippy
i am also interested on where to purchase a high output alternator.
sorry for reviving the oldness.
wheres a good place to purchase these wires? and any recommendation on type of wire to use? gauge/material/etc...
