How to replace turn signal bulb in front of car
WWNJCX7
Has anyone had to replace their turn signal bulb in the front of their car yet ?
It appears that my drivers side bulb is out and its not a simple operation to access and change the bulb. It looks as though you must remove the entire headlight assembly in order to access the bulb through the back of the unit. Not sure if that is the case or not so I wanted to run it by the board first and see if anyone had any insights.
TIA
NJCX7
i haven't looked, but i highly doubt you'd need to remove the headlight.
check your owners manual, the steps are in there.
Working again......
Well since I have been waiting to figure out how to do the replacement, it has started to work again on its own ? My guess is that it had moisture intrusion from taking the car out on a very wet night. I am having my headlight assembly replaced tomorrow due to moisture intrusion on the inner lens which happened the same night.
