How to remove the doors to replace speakers? Please assist
Ebruess
Cosmic Blue MS3
I just received my MS3 and the only thing I am not happy with is the stereo (from what I came from doesn't even compare). I would like to find a guide on how to carefully removed the door without doing any damage to the car. If you have a link that would be greatly appreciated! :)
there's two screws- one on on the door handle to open it and one on the grip handle. open up the covers with a small flathead and unscrew both screws- then just pull the panel up and away from the door using the grip handle. that's it!
I'm going to go and offer my install diary if you need it/want it. There is a link in my signature.
If you are replacing speakers, you have many options. If you want better then stock sound, you have far less options. My personal opinion is that the stock speakers sound decent, but the door doesn't. If you sound deaden the door (with Raammat as an example), you'll get good results even from stock speakers. Switch to better quality speakers, and you'll REALLY get results. The poor quality sound is due partially to the stock head unit "EQ'ing" the sound a bit too much, and the factory door panels completely undamped and bare. Again, check out my install diary and ask questions if you want or need guidance in this matter.
