Hello all,
In pursuit of roof rails that are both attractive enough and work, I am investigating placing a set of Ford Edge rails on the Mazda 5. As I want a solid attachment, etc, it is going to take some engineering and understanding of the underlying structure.
As a first part in doing this, I would like to temporarily remove the dark grey plastic strips that bridge the weld joints on the roof (not the plastic caps over the factory bolt places, the entire plastic strip).
Does anyone actually KNOW how these can be removed and replaced? I could guess, but... don't want to get in a situation where I have broken something which is even hard to order as it is not a "normal" part. Does it slide off one end, up pop up, or... you get the idea...
Thanks,
Chuck
Thanks,
Chuck
