How To: Kill your turkeys
505zoom
Breathe
2003 MSP #119
This guide is for people with aftermarket/custom hardpipes. For those of you who are running the stock plastic pipes, read this to get an idea of what you will be doing, and then refer to "Mach 3.5 Turbo's" thread for attatching the HKS to the stock pipes, found here:
http://www.msprotege.com/vbb230/showthread.php?s=&threadid=47267
If you have specific questions about the installation process, ask them here. Please put ALL other compressor surge related posts in my other thread: http://www.msprotege.com/vbb230/showthread.php?s=&threadid=39676, or in sonicraze's thread in FI: http://www.msprotege.com/vbb230/showthread.php?s=&threadid=39433. Or you can PM me.
I would like to keep this thread organized and informative. It will make it better for someone who needs help with the install.
The iON FMIC/hardpipes, and HKS SSQV are what were used on the car in the pics.
1. Assuming that you are running the stock by-pass valve (BPV), and hardpipes, choose an aftermarket BOV that you like. The HKS SSQV, and the Greddy type-S work for sure. You will also need a stainless steel or aluminum flange that is compatible with your new BOV.
2. Remove the section of hardpipe that connects to the throttle body(TB).
3. On this section of pipe, you will want to make a hole that is the exact same size as the inner diameter(ID) of your flange. Make this hole no closer than 3", and no further than 14" from the TB.
4. Have your flange welded(or weld it yourself) so it lines up with the hole that you made on the hardpipe. This cost me less than 25$ to have done at my local welder.
5. Attach your BOV to the now welded flange/hardpipe, and reinstall into it's original position.
6. Run a dedicated vacuum line to your new BOV, or tee into a vacuum line close to the manifold, and run as short of a line as possible to the nipple on the BOV.
7. This is the key: Leave your stock BPV in place.
8. You will now need to adjust your valve. Go on a drive and take a wrench for adjusting. The adjustment bolt on the SSQV is a 10mm. Start with the bolt at the loosest setting it can be without falling out, and tighten it 1 full turn for the initiall setting BEFORE you drive it. Test it and if it sounds like the valve is opening just a little too early, tighten some more. Repeat this process untill it performs and sounds the way you want. You want the valve loose enough to fully open under boost, but not so loose that it opens too early.
You're done! Now go and drive your gobbleless car! You can now scare innocent bystander's with a different sound:) Enjoy
If you are running hardpipes and an aftermarket BOV and are still getting the surge, the steps are simple:
1. Reinstall your stock BPV to compliment the aftermarket BOV you are running.
2. Give your BOV a clean vacuum source.
AWESOME job Rich...clear instructions and clear pics. Glad to hear you finally killed the turkey. Just in time for Thanksgiving too!
I'm not seeing your stock BPV anywhere in the pics after you installed the SSQV. Also, why do you have a MAP sensor hooked up?
The stocker sits right underneath the injen, you can see the hose that leads back to the injen in step 5. Here's a better look, the clear hose and elbow has been replaced;)
Where do you see a map hooked up? I don't have one:)
Yeah:D
^tyrant^ said:
great work man, nice and clean. this should get a sticky in the how-to
If a mod would like to put this there, please do. I wasn't sure about the process of getting it there.
i dont understand why one BOV wont work... it seems to work fine for all us boosted protege..
Our turbos must just be very easy to surge. I don't know of anyone who has put a msp turbo on a es/lx/mp3 protege yet.
What's zip tied to the A/C line in step 6?
I'm guessing you had another setup on this BOV which you cut the Injen pipe down, and thats why you've had to re-locate the stock BPV?
I'm not sure what that is. It was mounted on the stock IC----->TB pipe, and I had no where to remount it with the iON kit. I just zip tied it down.
turboge said:
I'm guessing you had another setup on this BOV which you cut the Injen pipe down, and thats why you've had to re-locate the stock BPV? [/B]
Exactly, trial and error my friend:D
first, i'd like to say AWESOME !
now, can u get some sound clips of ur SSQV ? where is the BPV connected to before recirculating to the CAI ?
also, does this mean that u're venting and recirculating @ the same time ?
Yes this setup is venting through the SSQV, while also recirculating through the stock BPV. With the BOV adjusted properly, you will not stall running like this.
Look at my picture a couple of posts up, and you can see where the stock valve is.
Here are the sound clips that show the difference between the HKS recirculated and the dual valve setup:
HKS recircualting, no stock valve:
http://www.wpi.edu/~jck15243/MOV00495.MPG
This is also very similar to the sound of the stock BPV.
New setup: HKS open vent, with stock BPV recirculating:
http://www.mazdamp3.com/members/505zoom/mov00533.mpg
so there is no way to do this without hardpipes? and how did u connect both valves, sounds sweet ass...im just a little confused on the dual valves?>!
im going to try in exactly an hour with a stock setup and HKS. it probably wont work, but ill post
I don't know of a way to do this without hardpipes, but that doesn't mean that it can't be done.
The stock BPV is left in place, and recirculating back to the injen. The SSQV is open-vent.
Excellent work Rich...now it's gonna be harder for me to wait til I get my FMIC! Have you put in the fins in the HKS to tweek the sound yet...it sounded like that clip was done before you put them in? If so, post some clips w/ the fins if you get a chance....thanks again!
DiscreetSpeed said:
hey Rich i so love the turbo bov sound..the way its suppose to sound...lol
Yeah man, I liked the turkey sound when I first installed the injen, but after awhile it just got annoying. After it became clear it was compressor surge, it almost hurt me to hear it.
