HOW TO: Install Short Shifter Plate + Weight
oh_yeams6
2006 Mazdaspeed 6 GT
Had an install-night with a buddy yesterday; I figured that if he was unsure on how to install this, others will be as well, enjoy:
Time Needed: 10 minutes
Tools:12mm ratcheting wrench
Installation:
  1. Place car in neutral and pull e-brake
  2. Open hood, remove stock air intake box (aftermarket will not require removal)
  3. Remove two 12mm bolts securing shifter weight- ratcheting 12mm wrench
  4. Remove shifter linkage - use two screwdrivers or a screwdriver + flat edge of wrench (hold on one side and gently pry up on the other)
  5. Place the SURE plate into position, but do not install the shift linkage yet
  6. Apply the a drop of the included lock-tite onto each of the new shift weight bolt threads
  7. Hand-thread the Countershift into position, then tighten the bolts using the included #5 allen key
  8. Place the shift linkage onto the SURE plate
**Note: Apply some white lithium or other grease to the shifter cables by pushing back the two rubber sleeves to make your shifting even smoother!
Impressions:
After doing some fast shifting he/I are very happy with this product; the drivability is greatly improved, and the car now feels more natural when shifting.
