How to change the fog light bulb?
  • Thread starter Thread starter Banana5
  • Start date Start date
Do a search. I have personally posted how to do this in the past, and I'm sure other people have too.
fog replacement
well steps are as follows i did it last night
1) unscrew the plastic gaurd that is directly infront of the driver and passenger tires
(or just remove the 3 of them and fold it back)
2) there is one large bolt that you can use an adjustable wrench on to remove it (dont lose the two washers) then push it out from behind the light
(becarefull not to pull on then you may en up ripping out the wires )
the wires are really short .. and so all you need to do is flip the light facing downward and then there is two or three screws that hold the glass casing on it .. (remove ) and bingo change teh bulb the back track all you did
ok for that i will need $100 for labor in telling you ..hehe im mennin ..but good luck
