how to change shift knobs for tiptronic mp5??
My shifter usually goes on around my knob.........(peep) then she takes me for a ride!! haha
*and I dont have much to cut off anyway so what i got is very important in my life!! And she sometimes calls it a lolly pop....but usually she calls it Mr fancy.
Hy8us said:
If you dont cut the stick your going to have about 2and a half inches of rod between your shifter and your knob, making your shifter look like a lolly pop.
your "shifter", are you sure you dont mean your "sister?"
hahahaha im sorry, i couldnt leave it alone
yeahhhhh ok i dont live in TX................
sorry i couldnt leave that alone....
here's my autotragic, i realize it's not the triptroic version, but i thought it came out pretty well...i'm gonna cut the shaft down too..
ooh thats a good one, but i think youre thinking of those alabama backwoods types
Hey Mazda-man, what knob is that ? Kinda like it. Where did you get it ?
mazda-man said:
there are some people asking how i mounted this shifter and i will tell you it was easy just unscrew the stock shifter first then take a 4.5" grinder with a cut off wheel and cut the factory shaft to the length that you need it mount the knob it was that easy
re:
ok here you go the top of the shifter has 3 screws in it that is how it is held into place as far as the mounting i had to cut down the shaft on the stock shifter for it to fit i used the length of one of the black sleeves that you see in the picture to get the proper length i didn't want to cut off to much then simply put it togther according to the instructions that they give you
