How-To: Adjust Foglight Height
DE31
In search for a life.
Pee 2+3
If you are like me, the original foglight height was too low for my taste, could also be because of the way the bowls reflect HID bulbs, but i decided to adjust the higher.
Just in case anyone is wondering bulb size is H11, wasn't able to find it anywhere else.
1. Remove foglight bezel
2. Located Bottom bolt, remove
3. Cut tab in the hole to allow higher degree of adjustment
4. Tighten and replace bezel
Heres a video, first half is the same as pictures above, second half shows degree of motion
(Sorry for the shakey one handed phone video)
How to Adjust 2014 Mazda 3 Foglight - YouTube
Cool thanks. I've been wanting to do this for a while but haven't gotten to it yet. Service manual says you have to take the fog light out to cut the tab and stuff. Did you have to remove the fog light housing to cut it?
Small Razer, tab is paper thin, exact-o knife will do
Pretty cool. I'll have to try this with my car. After you did this did you notice the fog lights being any brighter? I can barely tell when the fog lights are on with the Bi-Xenon's.
I swapped to 3000k HID fogs pretty much the night I took the car home, but before adjusting I was not able to see anything, noticeable difference after though
