How many MPG do you average?
2025 CX-5 NA w/CD
Digital MPG Trip A each tank 32-34 MPG, reset Trip A and self calculate ~30 MPG.
Driving habits...
i-Stop turn off always (each engine start)
Sport mode (manual select shift) vs Normal (auto) use 50/50
Commute in partial traffic highway and city 50 miles round trip, mostly flat.
Overall pleased with my fuel efficiency while enjoying being able to use sport or normal mode.
How about you?
40% Country Roads 40% Highway and 20% City = 30 mpg @ 4,000 Miles.
Have both. Na 23.4 Turbo 23.1. Mostly suburban driving. On highway both will avg over 30 mpg.
Ok around town looks to be a wider MPG as gap but near equal on the open road. I test drove the turbo but a shorter drive in town light to light.
2016.5 GT AWD. Averaging roughly ~19-20mpg with 90% city, 29-30mpg with 90% hwy, and about 22-23mpg combined with 65-70% city and 35-40% hwy. A bit lower than I think it should be, but not completely out of bounds with the EPA estimates for this vintage.
It's fairly easy to add another 1-2mpg (or more) on hwy if going easy, just plodding along, going the speed limit or slightly over.
In city-only driving I could be going a bit more sedately, but it's a lot of low-speed stop-and-go where I live. Lots of intersections with stop lights, and a fair amount of traffic to contend with. I typically go just over the speed limit and put it on "cruise control" whenever long stretches occur. So the city fuel economy is probably about as good as I can get, with my driving and on the streets I use.
About a month ago, I did a throttle body cleaning, along with one treatment of an intake valve cleaning regimen (through the TB intake hose). It seems to have added a good 2 to 2.5mpg for city-only driving. Same roads, same percentage on city streets, same hills to contend with, same relatively rapid starts away from intersections, and same occasional use of "Sport" mode ... so I am fairly confident this increase is mostly due to that cleaning.
It's fairly easy to add another 1-2mph on hwy if going easy, just plodding along, going the speed limit or slightly over.
Interesting with your results on the TB cleaning, seems the Skyactiv does require this as routine maintenance. That is a rather significant increase, so about how many miles between that service?
Uncertain of whether the vehicle has had prior cleanings of the throttle body assembly. Purchased it pre-owned at ~80Kmi. Had intended on doing a TB cleaning soon after purchase, but didn't get to it. Just did it at ~125Kmi, but I've been noticing sluggish throttle response since I've owned it, so I suspect the TB had never been cleaned.
I'm impressed by the improvement. Two things done, with this servicing: GDI intake valve cleaning, and the TB cleaning.
As best as I've been able to accomplish for estimating a change in fuel economy, I have tried this past few weeks to use most of the same roads, drive them the same way, accelerate roughly as I did previously, etc, in an attempt to get the estimate as near as I could. I'm guessing that the intake valve cleaning was mostly responsible for this aspect.
But the greatest change is how much smoother, better and faster the throttle response is when I touch the pedal. Just a mild tip-in, and it's quite likely to drop a gear and begin accelerating, particularly if under some load (as in climbing up a hill). A pleasant change, and I'm sure it's nearer to what the Mazda engineers had in mind when they crafted the car.
I've put it onto my own schedule. Hope to get to it in another 30Kmi or so. Sooner, if I detect the throttle beginning to become noticeably less responsive. Might also do the intake valve cleaning procedure then as well.
How hard is this to DIY, just for future reference anyway.
Very simple. If you look around the forum you should be able to find a few decent write-ups with photos. The various products' makers have how-to descriptions and videos on their websites.
Throttle Body cleaning -- First, be sure to order a new TB gasket, for when you seal everything up again. Basically, disconnect the NEG battery cable, remove the big hose from the TB itself (the one between the airbox and TB), then remove the TB from the engine housing. Using a good TB cleaner, soak the surfaces and then agitate with a brush and keep repeating until completely cleaned, being careful to not get any on the sensor parts. When done, wipe down completely and allow to dry. Using a good MAF Sensor cleaner, spray the MAF Sensor, then allow to fully dry. Reassemble.
GDI Intake Valve cleaning -- I used one of the sprays you can inject into where the big hose attaches from the airbox to the TB. The product by Berryman is easy to use, though I used the STP Pro Series cleaner. The product came with a simple list of steps. Go for a drive or run the engine until it's fully warmed-up. Remove the big tube off the TB, insert the thin tube from the cleaner hose into the gap, then reassemble the tube to the TB, with the chemical's tube aimed into the TB. Start the engine. Start the cleaner can, which will measure the volume of spray into the TB intake. When done, turn off the engine, allow the engine to rest ("heat soak") for an hour or so, then remove the can/tube and reassemble the big TB hose. Go for a drive.*
* The STP product recommends that the drive consist of the following: a 20min drive on the highway, followed by a 5min drive at 5000 rpms, followed by 10mins of driving to cool down. Some products recommend allowing the chemical to sit there for 1hr to soak the crud, though the STP product doesn't recommend this. I'm sure a soak following application would give the chemical a greater chance of digging into any tougher crud.
The only thing to be aware of is that some of the intake valve cleaner products don't have an "automatic metered" setting on the can, so typically you'd need a second person inside the car keeping the throttle speed higher. The Berryman product doesn't say that speed needs to be above idle, while the STP product recommends the throttle speed to be at 3000 rpms.
Pretty much, that's it. It is quite simple. Took me a couple of hours including the drive. A nice easy afternoon project.
