Empty is bad. It makes your car stop. Anythnig more that and it will run fine.DAWIV said:That article must have been sponsored by the refineries and gas dealers, especially at today's prices!
I've never killed a fuel pump by driving until the light comes on. Using gas from a station with old tanks could pose a sediment problem and get sucked up into the full system and running it empty could wear out the pump. Both of those situations are easily avoidable IMO.
Rotus8 said:Empty is bad. It makes your car stop. Anythnig more that and it will run fine.
Prove that it does(smash)moleodonuts said:Prove it. (pissed)
I proved it. I used up all my gas and my car stopped. I put gas in it and it goes again. I invite others to try the experiment to verify my result.BradC said:Prove that it does(smash)
I was agreeing with you. Disagreeing with the person that told you to prove itRotus8 said:I proved it. I used up all my gas and my car stopped. I put gas in it and it goes again. I invite others to try the experiment to verify my result.
(iagree)BradC said:I was agreeing with you. Disagreeing with the person that told you to prove it
Micah said:I run it down to E or slightly above nearly every tank. Then I figure out my mileage when I fill up. Ever notice your car runs better for a few minutes after filling up? That's because the gas in the tanks underground usually is at a much cooler temp than ambient.
