Well finally after almost a year i can start to mod my Speed3. Ive been reading about all the trial and error you pioneers have gone through and Im ready to put that experience to use as I begin my project. The core of my question is with a upgraded fuel pump (either mrlilguy or CP-E, havent decided) how far will a mbc and Split Second map clamp take me before I need additional engine management?? I'm not really satisfied with either the Standback V2 or AP in their current forms but want to be able to make some decent power.
In addition to those 3 pieces (cdfp, map clamp, mbc) I plan to have TBE, Synapse Hybrid BOV, Corksport FMIC w/ RAM Air intake, DNP exhaust mani and a Dashhawk for tuning. I figure I can get up to 18psi on the stocker as I have seen that done here already but I just wanted to verify. Can I upgrade to a GT28 or GT3071 with that setup? Can the map clamp change voltage enough to cause enough fuel to flow as long as the AFR is within spec?
Just curious what the limits are of this setup. Any comments or suggestions would be appreciated.
