How do you hook up a oil pressure gauge
I used the Prosport Sandwich plate offered by Protege Garage
It simply mounts between the engine block and your oil filter and you can run your oil temp and oil pressure gauge from that
Runs ya $35 or so? Maybe a tish more
Sandwich plate is definitely the easiest. Mine has several ports. So far I'm using one for oil pressure and oil temp. I think there's one open port left.
There are a total of 4 ports on the Sammich plate from Prosport. I am also running Oil temp and Oil Pressure
Block'd off the other 2 ports
For it to fit the Pro5 space, you'll need to wire them up the tow ports side by side.
i suggest everything eletrical, as do most everyone else. Hot liquids running into the cabin for a mechanical is a big risk.
