Hey i need to remove the map compartment door ASAP, I don't care if i have to drill it or take apart the dash. just give me some insight or a link with pics just something anything...(attn)
check the how-to section...there is a good write-up
unless you're asking how to get the map compartment out to then remove the door?
for that you need to follow the rmove headunit write-up, you actually need to remove center counsel, and radio tho get to the bolts to pull the map compartment. It actually sounds harder than it really is.
