high revs 2006 mazda 5
peterc4
premacy
Hi All
my 2006 mazda 5 with 67000 on the clockis reving at 2000 when slowing down in neutral then when you stop it goes back to normal it does this every time, anybody any ideas, cheers
Which transmission do you have the auto or a manual? If manual, does the trouble disappear when you push in the clutch?
Hi All
Did you replace your battery? Or did your battery go dead? If so, you may need to do an idle learn procedure to reset the idle to its normal range.
My 2005 did that too yesterday. Driving fine, but it wanted to idle at 2000 rpms. Turning the ignition off and on solved it.
It has done this once before, a couple of years ago. It then wanted to idle at about 4000. Problem then also went away with a reboot and didn't turn up till yesterday.
