- 2003.5 MP5 Laser Blue Automatic (SOLD)
I installed the HID bulbs last night and have a question. Is slight vibration safe with these bulbs? I looked at the bulbs closely before i put them in and i noticed that inside the bulb in the middle i didn't see filament like a conventional bulb so to me this would make the bulb more resistant to vibration caused failures. BTW i did use new rubber gloves when installing these and i didn't touch the glass part of the bulb with my fingers or any part of the headlight housing but i did notice that the clip that holds the bulb inside is slightly looser as the bulb is actually the same dimensions as a standard h7 bulb and the supplied adapter did not allow me to clip it in when installed so i only used the bulb itself without any adapters. the standard p5 h7 clip didn't seem to put a lot of pressure on the bulb but after driving i didn't notice a lot of vibration but when i hit some rough pavement they appeared to twitch slightly but they don't look like they have any possibility of falling out of the h7 matched hole in the headlight reflector where the clip holds them in. im brand new to hids and just need some info about this slight vibration. Thanks
