NB MX-5 Hey, it's Minnie!
Had some medical appointments that occupied my time this morning. When I got home I shot the spats with four coats of clear. I think they came out decent. After that, I had one more task to accomplish.
When I cut off the bottom of the spats I lost two of the threaded inserts (per side) that dcbe provides to allow you to use screws to attach them to the bumper along with any double-sided tape you want to use. One of the inserts got cut in half because I didn’t see it was in line with my saw. I was able to salvage the other one and held onto it. These inserts are brass, threaded M3 on the inside with some sort of knurling on the outside to hold it in the material. I picked a spot low on the spat and eyeballed the location for the first one. Measured distances so I could drill the other spat in the same spot. The insert measured 3.75mm OD. I don’t have many metric drill bits, but I do have a number drill index. I just pulled a bit that was close and gave it a shot. I then progressively went up in size until I got to one that let me mount the insert snugly (that ended up being #21). Here’s a picture of how that looks:
My plan is to get these mounted to the car tomorrow. No pictures until then, you’ll just have to hold on to your excitement.
Got started this morning. First job was to transfer the location of inserts for the mounting screws. I decided a while back to try using a form of centering screw for this. I bought some M3 set screws that came to a point for this. Tried 12mm long ones but they were too long, so I went with 3mm long (would have been better to use 5-6mm but couldn’t find those). Sorry for the blurry photo, my phone didn’t want to focus but you should be able to get the gist of what I did:
I tried just pushing those onto the bumper but didn’t get very good marks, so I used some painter’s tape and marked it that way. It was just good enough for me to see:
Once the holes were drilled I temporarily installed the spats with screws to make sure I had the holes where they needed to be (not all were so I had to drill other holes, half of them were off by a little). After I had them located I removed them and put on the double-sided tape like so:
If you haven’t done this before, you peel back the backing a little and fold it over to let you pull it off all the way once you get the item in place.
End result? Here it is:
I’ll get some distance shots from outside which may help seeing how it looks as part of the overall package.
Took a couple more shots today facing the opposite direction, highlights the spats from the front better:
Looking cool! I didn’t realize their aero importance! I always thought of them like a mud flap.
Yeah, all the cool race cars have some form of them. :cool: I have been noticing on modern cars that a lot of them have the bumper going out far enough to act as an air guide around the front wheels.
I mentioned about possibly replacing the parking brake cables because of not being able to adjust the handbrake where it needed to be. I did some research and found a couple of places online that had decent prices. I decided to just replace the front cable to the lever for the time being as it runs about 50% of the cost of the two cables that join it to the rear wheels. I placed my order with www.mazdaparts.us and got the cable a few days later:
Part number on that one is NA01-44-150D. Had some time today so hoisted her into the air and set to it.
First I removed the driver’s seat and center console for better access. Pulling back the carpet cover reveals the parking brake lever, held in with three bolts:
I then went underneath and scoped out what I had to remove. The cable penetrates the body above a heat shield that has to be removed:
This one is a little tricky, you can see three bolts holding it but there is a fourth one hidden above the exhaust and driveshaft. Here is the shield removed:
I was lucky to be able to get to all the bolts with how my car is configured and the tools I have, not sure how much harder it would be with stock components. Once that’s out of the way I could see the connection to the rear cables:
Sorry for the blurriness, my camera wouldn’t focus where I needed it to. You can see the spring that keeps tension on things, as well as the bracket that connects the handbrake cable to the rears. That was a little fiddly to get out thanks to 26 years of weathering. I found it best to remove the side of the spring connected to the body. There is also a small bracket holding the mid-point of the cable like so:
Once those are all removed you have to remove the grommet the cable passes through to the cabin and then pull the cable out.
Grommet is the black piece at the bottom of the picture. When I had it all out I compared the length with the new cable but didn’t really see any difference.
Assembly is the reverse of the above, I used some silicone spray on the body penetration grommet and it slipped right in. I cleaned up the heat shield as it had some junk on it (from when I had to drive her with deicer on the roads). All fasteners underneath got a lick of antiseize. Once the brake lever is back in you can adjust its pull. Before I did that I readjusted the rear calipers to have everything at a good baseline. End result of this was I was able to get the lever adjusted to be tight at 5 clicks. This will suit me for now, although I do plan on replacing both of the rear cables so the whole system is new.
FYI, part numbers for the rears are as follows:
Driver’s side: NC10-44-420A
Passenger side: NC10-44-410A
Yes. I posted it in here quite a while ago. I ended up using a piece of PVC pipe with a slice in it to sit on top of the roll bar, that raises the rear of the top so it's more level. Not 100% but it works.
A couple of days ago I decided to hard wire my dash cam. I pulled apart the lighter plug to get to the wiring. Apparently when I did so my ability to add 2+2 went out the window, because there was a small circuit board nestled within. Didn’t make an impact on me, I proceeded to make up the wiring I (thought) I needed to do this. This included soldering wires onto the cigarette lighter connections. While doing that I managed to burn myself when I was transferring the soldering iron from one hand to the other. That smarted. Got it all hooked up only to find it had no power. Back to the drawing board.
Doing some reading of the instructions I found out that I needed a step-down power supply to properly run the cam. Another clue to this, had I been paying more attention, was the fact that the cable to the cam uses a USB-C connector. I hooked the cam up using a phone charger to see if I blew it up, luckily it came to life. I checked for the hard wire kit I needed, the company I bought the cam from didn’t have any in stock so I got a generic one from Amazon. It came today so I got it installed. Ran the new power cable up the A pillar like the first one, and across the metal bar behind/under the glove box like so:
The power supply looks like this:
I ran the wires and power supply behind the center console and into the area of the cigarette lighter. I then made up my connector on those wires, and mounted the power supply using some industrial strength Velcro and a small piece of double-sided tape for stability. That looks like this (note, I ended up shifting the power supply to the right as the connector for the air bag switch/off light occupies the space where I initially mounted it):
Put everything back together and she fired up. Cam is now as hidden as I can make it and I don’t have to worry about the wiring getting snagged on something.
Nice work!
I never used to feel like I needed one, but with how many poor drivers I see of late (especially when I'm in the Miata) I think it's a good idea to have it.
There seem to be a lot of people who find the need to get right on my ass here lately, especially at stoplights. Given that, I decided to install the rear cam that came with my dash cam. On my car it ended up being not as bad of a job as I thought it would. First off I installed the camera on the trunk lid with the supplied double-side tape:
You can see I ran the wire through the latch, the heads of the rivets allowed enough room for the wire without pinching it. The wire runs across the trunk seal but I don’t think it will cause any problems (I’ll be keeping an eye on it). I did not want to be drilling any holes back there.
The manufacturer conveniently made the supply wiring with a quick connect a short distance from the camera. That made my decision on how to run the wire for me. I started up front, plugged it into the camera and then ran the wire along the power wire down the A pillar. Once at the floor I found Mazda nicely provided an empty black plastic tube running from the A pillar area back to the seat belt area. It lies at the turn of the floor where it goes from vertical to horizontal so it’s well protected. I tried just pushing the wire through but it stopped about halfway, so I broke out my fish tape. Pushed that through from the rear, taped the wire to it and then pulled it back. Here is how I did that, if you look in the background of the picture you can see the tube I used:
From there I just ran it into the trunk. I was lucky in having a roll bar, the fuel tank shield cuts for that were big enough I was able to snake the wire back that way without removing the shield. I zip-tied the wire to existing factory wiring to keep it neat and tidy. Once back in the trunk I ran it up the passenger side hinge and then up to the camera connector. Here is that showing how the two ends of the wire connect:
I coiled up the excess wire, zip-tied that together and then stuffed it behind my trunk lid organizer. All nice and neat. Tested operation of the camera and adjusted it to give me the best view. I can see a reasonable distance behind me up to my rear end.
Well, time to go back to work. I was off longer than normal this time due to health reasons, but the doctors gave me the green light so off I go. She got a final bath this morning and I took a nice little fun drive afterwards,
There won’t be any posts until I get home again down the road, but stay tuned!
Health is #1, thanks for the heads up...Staying tuned and stay safe out there!
Sail on sailor.,😉
