RockyMtnSpeed3
- 2009 CWP MS3
Sorry in advance if this is an extra post on the topic. I just want to make sure I'm doing this right since this will be the 1st time I've jacked up my MS3.
Basically, Im gonna paint/decal my calipers w/ a G2 kit later today/tomorrow and want to confirm how to properly lift it w/ a floor jack and put it on 4 jack stands.
So from searching around and putting recommendations together, it sounds like the best/easiest way to get on 4 stands is:
Prep:
Finishing Up:
Does that sound right?
I've always only jacked up the front or rear on my other cars so I'm a noob jacking the MS3, particularly on 4 stands. I'm using the G2 paint kit and going w/ people's recommendation to paint all 4 as quickly as possible since the paint cures quite fast.
Also, is it necessary to use a piece of 2x4 on top of the floor jack when lifting from the rear/front cross members? Sounds like other recommend using a piece and Im sure Ive got one somewhere in the garage but will save the search time if its not absolutely necessary.
Again sorry for the addtl thread...just want to be 100% sure I'm doing things right so I don't mess something up or get injured, lol.
Thanks in advance and hope this may help others doing the same in the future (thumb)
RMS3
Prep:
- Drive the front wheels up on boards
- Loosen lugs on all 4 wheels
- Use floor jack at the front cross member (b/t the front wheels towards the driver side) to lift front wheels off the ground
- Put the 2 front stands under the front pinch-weld jack points and gently lower floor jack onto stands
- Use floor jack at the rear cross member
- Put the 2 rear stands under the rear pinch-weld jack points and gently lower floor jack onto stands
Finishing Up:
- Wait 2 hours for paint then put wheels back on, lightly tightening lugs.
- Use floor jack at rear cross member to lift enough to remove rear jack stands from rear pinch-weld points.
- Lower floor jack from rear cross member
- Move floor jack to front cross member. Lift enough to remove front jack stands.
- Lower floor jack from front cross member and tighten lugs to recommended torque.
- Wait overnight for paint to fully cure
- Enjoy and post pics(yes)!
RMS3
