Help, I have just installed a new ATP GT3071R Turbo Kit for Mazdaspeed6 supplied by **********. All went well with the install until it came time to start for the first time. It fired up first start with billowing white smoke spewing from the exhaust. i let it idle for a few minutes thinking it would burn off, checked underneath and oil was dripping from the join between the new test pipe and the old exhaust. I disconnected the old exhaust and started it up again with just the test pipe. Apart from the smoke, oil dribbled from the pipe (a 10" puddle in about 2 minutes idle). I have since removed the test pipe. The turbine spins freely and there is no noticeable play or movement there was
a puddle of oil on the bottom of the exhaust turbo outlet. Any advice or constructive recommendations appreciated. Being in Australia makes it difficult to get answers sometimes.
