L LBV Member Jan 22, 2009 #2 You aren't clear if you're removing the old one and replacing with a new one or removing the old one and changing just the internals (as I and many have done = cheaper) ... if it's the latter, the attached is the best set of instructions I've seen. Attachments CDFP Kit Install-HOT.pdf CDFP Kit Install-HOT.pdf 992 KB · Views: 300
