HELP need O2 signal modifier
T254Power
undefinedI have a 3in custom exhaust from the S-pipe back and natuarlly within the first 24 hours of having it on the it threw a code so I need to find a o2 sensor signal modifier in order for the code to go away. This is kind of a larger problem than it seems cause my inspection is due so I need that modifier fast. If any body nows any thing let me know pleas.
silver 03 msp- VIS CF HOOD, B&G LOWERING SPRINGS, APEXI TURBO TIMER, APEXI SAFC (NOT HOOKED UP YET), GREEDY BOOST GAUGE, AUTOMETER EGT GAUGE, AUTOMETER GAUGE POD, HKS SSQ, GFB MB, K&N FILTER, 3IN CUSTOM EXHAUST.
hey use the spark plug non-foulers. Works great and you do not have to splice you wiring. Very easy too.
it prevents the plug from getting fouled when one has an older oil burning engine,but for us and other non cats out there the o2 screws onto this and in turn you screw it back into the o2 bung, oh yeah i almost forgot that you have to ream the fouler a bit with a 1/2" drill bit works wonders for not having to deal with a CEL.
