dominoy2k1 said:
it runs good without it.....just that every now and then it will go into really low rpms..but runs almost like stock...
linux: backwards?....
Yes, backwards. I forget who did this. (Linux?) The MAF is just a tube. If you install the tube backwards, you can have some serious stalling issues. "Backwards" would be intake side facing the TB, and TB side facing the intake, so the flow of air would be moving through the MAF in the opposite direction that it is supposed to.
The "after driving" thing makes me think it could be a leak after the MAF, which could happen once the car warms up and the ECU changes from cold to hot running.
The car can run w/out an MAF, technically. It will run based upon input from the O2 sensor (for rich/lean after the fact) and other sensors on the car. It is not SUPPOSED to run like that, of course, but it can.
Lastly, to properly reset the ECU, you must drain the capacitors. When you disconnect, depress your brake pedal 10-15 times. This may have no effect.
Lastly, if you have the means, just run compressed air through the system and listen for leaks. I would say that 75% of the folks that had initial problems with their turbos found the problem to be a vac leak somewhere, often AFTER checking every fitting.
This could be true ESPECIALLY if you had no stalling issues at install. Something may have come loose, a situation that I know has happened to Linux and a bunch of other folks.
