my p5 is throwing this code after i removed the vtcs===>> (P0171)
my car idles low 500-700... it fills like is going to die on me every time im in a red light......
i replaced my 02 sensor and is still throwing the same code, now im thinking of replacing my maf sensor as it could also be defective.....
i have one question about this problem before i replace the maf sensor
whats the odds that my maf sensor is good thinking about that there is more air going through because i remove the vtcs?
i read through some threads and some guys where having the same problem one of them swapped the mp3 ecu to his p5 and the problem went away....
should i try this first??
Faulty readings from other sensors such as a Mass Air Flow Sensor. You may actually be getting more air than the MAF tells the computer
