As the title reads, seems like the tien h.tech springs I've installed don't want to stay put in the rear top mounts.
Previously, I had espelir springs with tokico hp blue struts which served me well, with the axr clunk fix bracket and racing beat rear sway bar, for over 125k miles accumulated over a decade. It was a great setup.
Recently, I updated the suspension to soften the ride to be more OE for my newborn child with tien coil springs paired with kyb gr-2 struts including new sets of top mounts and endlinks. But now I've been troubled with having to realign the rear coils into the top mount rubber isolators multiple times because they keep popping out. I think my driveway is the cause of this because it's quite steep and I requires me to exit at an angle, to avoid scraping, turning onto the street either left or right. Either way I turn the car is momentarily a tripod with one rear wheel dangling in the air with its suspension uncompressed. This is when I suspect the spring pops out of the top mount. Obviously, this unmounted coil is causing a lot of noise back there and it's really frustrating.
This never happened with my previous setup so I'm also suspecting the kyb struts or perhaps the tiens.
Is there anybody here who has faced this issue and come up with a solution? Balls!
Sent from my iPhone using Tapatalk
