Help: Installin Boost Gauge
Equinox
Daddy Warbucks
Contributor
09 370Z Nismo
Hey guys, need a little help installing a boost gauge on my mazdaspeed3.
I'm putting it on the steering column, and I need to find a place to run the parking light wire, the ground wire, and the car on (accessory) wire. Normally I'd hook these up to the fuse box under the driver foot well but this car moves the fuse box to the passenger side, I can, with extra wire just run the wires there, but I wanted to know if anyone has done this on these cars before, and found a better place for these pickups, or did you guys use the fuse box? Thanks for the help.
For power I used the ignition switch. My grounds are the silver torx screws on the top of the colum (cover is off obviously). My light source is with my power but your park lamp wire runs right past there. Take the turn signal stalk down and find the right ilumination wires in that. If you need help PM me I will have my car appart to install a turbo timer in the next few days.
Similar Threads and Articles
