Help! Ignition Problems
roadog1
I have a 1994 Protege with a 1.8L SOHC engine. The car will crank but will not start. It does not have spark. I have replaced the coil, and the ignition module, also replaced coil wire goin to the distributor cap. Still no spark. Before I go any further, I sure could use some advise. This has been quite expensive already and to no avail. I have also made sure the timing belt is not broken or stripped out. Any advise is gretaly appreciated.
Thanx, Roadog1
