HELP Guage Cluster NOT WORKING!!!!???
msp_rad
2003.5 mazdaspeed protege
i just installed a 626 intake mani, and took the car for a spin,,,, the guages worked fine, but the second time around, all the guages dropped!!!!!!!
my temp,fuel,speed,tech guages dont work.. why??????
check the fuse. i recently had this happened, but everytime i put a new fuse in it would blow again. after checking wires connected to cluster and then reviewing wires and work that i had previously done i found that i my speed sensor wire was burnt due to replacing my egr tube w/ water heater tubing in the how-to's....check your fuse though
thanks for the replies, thats exactly it........ it was the fuse, but when i put a new one in, it just blew again....
i just did work with the egr, so ill check the speed sensor,
AS soon as someone tells me WHERE IT IS??????
thanks
I know Im bumping an old thread...but you sir, just saved me a HELL of alot of time. Same exact problem. lofl
