Help canadian P5 owners
cantin03
Hi,
Do Canadian 2003 Protege5 comes stock with a block heater? If I got one, where it should be located. I'm looking for the 120V plug and I can't find it. (uhm)
Thanks a lot.
No they don't come with block heaters.
Block heaters IMO are unneccesary, just use synthetic oil and your car will start up just fine.
And the block heater is also no longer available. I have one and love it on those really cold nights, although I have to say that I used it a lot more when I lived north of Timmins.
They may not be totally necessary, but they sure are nice to have.
Ya its cold out there right now like -30 degrees celcius.. brrrr
This morning my car started after 10 seconds of turning :S
you can get an aftermarket inline heater, they keep things pretty toasty!
I love my block heater for cold nights....so does the car haha
Dude you live in Quebec, you have to get a block heater it gets cold, synethic oil doesnt have anything to do with the fact that its going to start when wind is blowing in your grill at -40.
Block HEATER IS A MUST!
Yes, I really need one these days. I bought the car used, maybe there's already one. Do you know where on the engine it should be placed?
Thanks!
normally your block heater is on the other side of the frost plugs....it's on the inside of your block.
Yeah we know what cold means these days in Qc lol, -34 C this morning here, I wish I had a block heater this morning but still it started..! Yay! (wiggle)
l^^^ thats crazy man lol.
Still not good for your engine long term.
they dont cost much and yeah right side under neath by your batttery is where it goes.
Like I said before with synthetic oil there is no need for a block heater, sure it wouldn't hurt, but its not a necessity. Synthetic oil maintains a more constant viscosity in cold temps meaning it stays more fluid compared to dino oil that just turns to molassus. Take a litre of dino oil and good quality synthetic, leave them outside for a few hours then try to pour each of them, the synthetic will pour almost like normal, the dino oil will be like thick syrup.
The whole purpose of a block heater is to keep the oil warm and fluid for startup, but if synthetic is already fluid....see what I am saying.
I have owned 10 cars over the years and never had a block heater, never had a problem...most of them ran synthetic.
^^ actually your forgetting that a block heater doesnt only heat your oil but mostly it heats your coolant.
And if your coolant starts to freeze thats not good.
so if you want to perserve your car than a block heater is important.
if you own 10 cars over the years that means you dont own one for very long, i can tell you that after you use your car for over 10+ years with synthetic it wont matter it will freeze up my transmission started to cease up, the heater will heat up the general engine compartment.
LOl this is funny cause i just bought a speed 6 in B.C. that doesnt come with a block heater.
and im going to the mazda dealer to instal a block heater, at the cost of $250.00 the block actually costs 80 bucks.
worth it if you want to keep your car in Canada for a long time.
It's a known fact that most of the engine wear occurs at cold starts, synthetic definitely has the edge over Dino. But for the small cost in electricity, versus less wear and tear on the engine I know what gets my vote plus you get heat from the heater way sooner, what the hells wrong with that.
It's like a big strong guy with his hand in a fire, and tears running down his cheeks, and saying I can take this. WTF make life harder than it has to be. Block heater FTW.
Pat.
When did Canadian P5's stop having block heaters?
I have a 2002 and as far as I'm aware it came stock with the 120V plug/cord wrapped around the hood stopper just near the driver side headlight. Also the plug itself has a removable rubber boot to protect the prongs, so it might appear to be hiding.
when? since the first day they were sold!
just because you live way up there doesn't mean you can assume all cars comes with one from the factory! mazdas always had optional block heaters and they were all installed either at the port or the dealers!
^Yes, it is an optional accessory.
Alberta cars often come with this as "Standard equipment" offered by the dealer, as the dealers have the block heaters installed and tack it on as additional price to the car.
Everyone wants and needs a block heater in Alberta so it's more cost effective for the dealers to have it pre-installed in the cars.
Fair enough. I bought my car used so I wasn't aware, but I did suspect the dealers have had them installed, or they would be installed in the same way day time running lights are implemented from Mazda upon export, or import (assuming this is correct).
