Help! 2002 626 4.0L Motor Mount Inserts
Makenee
I'm a neewbie here so please bear with me.I hope I posted this in the correct area.:)Well,I have a 2002 Mazda 626 4.0 liter that is in need of some motor mounts.My car shakes a lot now and I noticed the mounts are bad.I've been searching all over for some polyeurothene inserts,but I can't seem to find any.Does anyone make these?I replaced my older eclipse with some red ones a few years ago,and the inserts were actually better than the oems!It handled a whole lot better and was way cheaper than replacing the original mounts.I want to go this route if possible.Can anyone help?I want to keep my original mounts,and just replace the worn/cracked rubber inserts.Any help or links to where I can be helped will be greatly appreciated.Thanks.
Help!
I have 2002 Mazda 626 4Cylinder 2.0 Liter. Sorry for the confusion.I'm just so tired from internet searching for these darm things.(sad1)
Help!
Thanks GoFast! I will try this tommorrow.I read this and I noticed that it said if I do this to my mounts, my car will vibrate a lot more.Should I just try and fill in the spots that are torn only?Would that work or do I need to fill it all up for it to bond properly like the instructions say?I definately don't want my car rattling or shaking inside.It would drive me mad!Have you used this method yourself?I was just curious.If you did use this method,what were your results as far as the vibrating inside the car?Let me know.Thanks.
you have 3 options, AWR aftermarket mounts which will vibrate a LOT (I have their hardest rear mount in, and honestly it doesn't really bother me that much), fill the stock mounts which will vibrate some and could fall out eventually, or buy new factory mounts, which will wear out again...
Help!
Ok guys I have just went to every auto parts store around here and I cannot find the 3M Windo-Weld Primerless Super Fast Urethane Sealant.Is there a hardware store that carries it?Lowes,Home Depot, Ace Hardware? I will try and go to Ace Hardware in a few minutes,but I want to go this route as I got quoted $179.00 for ONE mount from Auto Zone!I don't have that much money to spend.I can only imagine what an OEM would cost.WHEW!Am I glad I came here first.Thanks to everyone for your help so far.
all good places to look.
Thanks Evil! I have about $80.00 so I will buy this set when I get the rest.For now,I think the 3m Windo-weld is the temporary solution.Thanks for the link.WOW!
