Headphone broken as described in Service Bulletin
I got one broken as described. Do you think this will be covered by warranty?
Thanks
Not sure what you mean as described as nothing is described. If it was a manufacture defect sure, if you drove over it maybe you can get a discount on a new one from the dealer.
Well then according to the link it plainley states:
REPAIR PROCEDURE
1. Verify customer concern.
2. Replace the broken headphone with a modified one.
REPAIR PROCEDURE
So I just wonder this will be covered by factory warranty? Anyway, I will ask the dealer.
I had a replacement without any problem. Even though, the service bulletin says it will be replace with a modified one, but I don't see any difference.
I took a print-out of the service bulleting with my broken headphones and the dealer replaced them with no questions.
If they post it on a recall, then they should replace it under warranty.
