20EVOLUTION01 said:One more question before I take the plung...........
I know I ask to many questions but I want to be right.
Any year from 93 to 97 from the 626 2.0 right. I will then have to weld the 2nd O2 Bung, if not on, and modify the end where the flange is that connects to the exhaust. Also I meant to say if the EGR line was bendable. It looks like it could bend. If not oh well.
tonkabui said:oh, the EGR line isn't bendable either. we tried. it's easier to just make a new EGR bung. as for the 2nd O2 sensor, i say just get the one with 1 O2 bung and make a test pipe with the second O2 bung. then use the MIL eliminator. i am not sure if nogales has emissions, cause if it doesn't, don't bother with a cat unless you don't want to smell unburnt gas exhaust. it does stink.
I was the test car for that particular design (2.0L) - as posted by me on this board and on the other U.S. board last summer.gino said:I'm running Kevin's shorty "bundle of snakes." Perfect fit, excellent build and finish...
Installed it and ran a dyno check. Surprised the hell out of all of us during pulls. No increase in WHP, no increase in torque over previous non-header runs with Injen CIA and Magnaflow CB. Go figure. ES claims 7 hp increase and around 10 ft/lb increase in twist. Called Liphard and told him what the dyno said, even though the car is quicker by the clock. He was baffled; couldn't figure the dyno readings.
You're right Josh, other than the shorty, the rest of the car was bone stock. Just to let you know, I'm not passing judgement on the header itself, nor the craftsmanship. The puzzling thing was that Cruisin had a shorty header installed from ES (an earlier design), that produced noticeable results - so I went in with skewed expectations, I guess.Gen1GT said:I wouldn't judge the ES shorty header until the first cat and stock downpipe are replaced with 2.25" piping.
I'm sure the stock manifold IS bad, but it doesn't mean it's the weakest link. With a cat and crappy downpipe right after it, it wouldn't matter HOW well designed the header is. A 200whp engine is only a 50whp engine blowing into a straw. No different on how I only got 3whp peak with my 2.5" exhaust. It wouldn't matter HOW good my exhaust was, when the stock manifold is so bad. You need to work on your weakest link first.p5sundevil said:well i dont know about that. if Es was posting those supposed gains on their site I would Assume(unless they state otherwise, which they didnt) that that is on a stock car.
Also the point of a shorty header is to keep the stock cat, so even if you plan on getting a DP with cat later they should not tell you you can buy their header but dont expect gains untill you also buy the DP.
I dont know I wasnt expecting much but at least 2-3whp more since our stock mani is so bad. but who knows.
Unless you live in a state that does emissions testing, you should just go with a full header. Install isn't that difficult.illwill84 said:Ok.
You mention that Wagner offers direct bolt on replacements for the downpipe as well as the midpipe. They also offer high-flow cats.
Which of these pieces would I need on top of the shorty header??????
I am looking at getting some gains without going crazy with install. I just want something that will bolt on and be done with.
