dizwhoadayjohn
- 09 MS3 CWP
PTP hpfp ftw!
Where you running 440's by any chance cause I'm starting think that for those who have not fuel cut in the winter are using 440's. Wondering if that might have anything to do with it. All I know is that my FTC with a built in map of 21psi still caused me to cut.
Actually, yes. But that has nothing to do with it. The signal from the MAF has nothing to do with fuel. If the MAF signal goes above 4.7v it will hit fuel cut regardless of a/f ratios, or injector size. The MAF reads intake air, and the MAF has no way of knowing what injectors or how much fuel you are using, so how would that make a difference?
The reason I mentioned this though is because I noticed with stock injectors...if you ask the AFC to add fuel...well for me anyway it will fuel cut even if the cel value is just 10.1.
Also, I've read that if your tuning with a P5 ECU on stock injectors...if you ask the AFC to add fuel you max out the MAF. But if you use 440's it seems to be ok.
This is why I started relating injectors with maxing out the MAF.
with bigger injectors, (like I said already) you give the ECU a lower MAF voltage, because a shorter injector pulse on larger injectors delivers the fuel you need. (higher rate, shorter duration)... this eliminates fuel cut almost absolutely.
outlaw, you deleted the post that explicitly explains the function of the SSAFC in avoiding fuel cut... can you put that back up please?
"shouldnt" be a problem. but you can get a problem at stock (6lbs) of boost. everyones car is different. and if you have the stock WGA + no MBC then 9lbs of boost isnt possible unless something (wga) is failing.
